Triggering Germanium
A project log for Clockwork germanium
A retro version of Yet Another (Discrete) Clock, with vintage parts
shaosSHAOS • 04/10/2016 at 03:11•16 Comments
So going further with replicating circuits from old Russian magazine (1983):
Now using 2 NANDs (version with LEDs) I built trigger (as on Fig.7 above):
Then added couple resistors and couple capacitors to get universal trigger (as on Fig.8)
That can toggle state if inputs 5 and 6 connected together - 100 Hz:
1 kHz:
5 kHz:
It looks like this is a limit (and trick with "speed-up" capacitor doesn't help) - probably I should play with values of resistors and capacitors...
UPDATE: Everything above was for C1=C2=10000 pF, now I'm trying 470 pF
10 kHz:
20 kHz:
On 50 kHz it doesn't look good...
UPDATE (04/10/2016): Today 50 kHz looks much healthier - I don't know why :)
But if go higher output shape is quickly shifted up (to the ground) - probably because of natural limit that caused by latency about 5 us...
P.S. Almost forgot - 32 kHz sine signal :)
P.P.S. Redrawn schematics:
Note: Wires that goes above diodes are NOT connected to diodes' cathodes as may mistakenly appear in your mind (check closely - there are no dots there)
Yann Guidon / YGDES wrote 08/23/2023 at 02:22 • point
I see : the bases are tied with 1K (that's quite tough), and there is a LED in series ...
SHAOS wrote 08/23/2023 at 05:39 • point
LED is used instead of silicone diode that shifts threshold - in some of my previous logs here I also tried Zener there and it also worked ;)
https://hackaday.io/project/10698-clockwork-germanium/log/35378-2nd-approach
Yann Guidon / YGDES wrote 08/23/2023 at 10:43 • point
and no parallel capacitor ? The 1K on the base draws quite some current...
Yann Guidon / YGDES wrote 04/11/2016 at 05:03 • point
Thanks for the drawing :-) BTW you should also have a reset input, but that's just one more diode.
Yann Guidon / YGDES wrote 04/11/2016 at 03:35 • point
Nice touch with the 32KHz signal :-)
jaromir.sukuba wrote 04/10/2016 at 15:35 • point
I assume for a few first stages of binary divider we need to use faster transistors - the same as in oscillator. let's spare the lazy MPxx for later stages. we will need a lots of them
Yann Guidon / YGDES wrote 04/10/2016 at 15:38 • point
That's exactly my idea :-) That's why I'm stocking less lazy parts too.
Yann Guidon / YGDES wrote 04/10/2016 at 04:03 • point
What's the value of the resistors and capacitors ? Can you redraw the whole diagram ? Arent's some diodes superfluous ? I should try the DCTL version as used in the CDC6600...
SHAOS wrote 04/10/2016 at 04:07 • point
All resistors are 10K as on the picture 8. For capacitors instead of 3300 pF I took what I had on hands - 10000 (marked 103)
Yann Guidon / YGDES wrote 04/10/2016 at 04:17 • point
Faster gates use lower resistor values, AFAIK, so this might explain some speed limits... Can you try with 1K and see how much faster it runs ?
SHAOS wrote 04/10/2016 at 06:14 • point
I tried 470 pF - works up to 20 kHz
Yann Guidon / YGDES wrote 04/10/2016 at 06:32 • point
Hey it is "almost there" :-) Could you try with a sinewave input ? That's what the 18KHz generator will provide...
Yann Guidon / YGDES wrote 04/10/2016 at 16:09 • point
Well, I realised something: trace shapes are an esthetical thing, since Ge commutes at about 0.2V so as long as the circuit reaches even 1V it's ok. Now I wonder how your diodes influence this...
SHAOS wrote 04/11/2016 at 03:29 • point
I'm not sure what do you mean exactly :)
Yann Guidon / YGDES wrote 04/11/2016 at 03:34 • point
Well... I'll experiment :-)
Yann Guidon / YGDES wrote 04/10/2016 at 03:27 • point
It's starting to work ! I'll have to analyse the schematic and try with other kinds of transistors...
