Pick it up.
06/15/2018 at 10:27 • 0 commentsHow do you handle wafer pieces to submerge them in HF acid and other cleaning baths?
You use tweezers, but HF will eat away any metal ones, and I would not trust much else other than HDPE plastic that can withstand it. However, I did not find accesible (cheap) ones, so I decided to make them, it's funnier and cheaper.
Too thick stock coupled to a short endmill marred the results a bit, but it proves the point, once I get thinner HDPE sheet, I'll make some more.
(and nope, my 3D printer is not working properly)
This Boring Company
05/25/2018 at 16:23 • 0 commentsFollow-up in the tubular oven work:
Blog post about it (updated post): https://electronicmercenary.wordpress.com/2018/05/16/this-boring-company-part-1/
Bored? Watch a sputtering rig:
05/15/2018 at 13:13 • 0 commentsJust a plain uncut video of copper sputtering too close to the plasma, with time anotations so you can skip to the interesting bits.
Blog post about it: https://electronicmercenary.wordpress.com/2018/05/15/bore-doom/
Pride and Depositionize.
05/14/2018 at 13:47 • 0 commentsToday I finally started to characterize the vacuum chamber, and also had some fun.
Blog post about it: https://electronicmercenary.wordpress.com/2018/05/14/pride-and-depositionize/
Stupid led circuit on glass, just before soldering:
The copper was too thin, and the solder paste just destroyed it when melted. In any case, the deposited copper passed the finger rubbing test, so, making circuits is just a factor of the time allowed in the chamber.
The Goblet of Fire
05/10/2018 at 15:49 • 0 commentsMaking a liquid cooled plasma trap/catode for the sputtering chamber, so it can operate for extended periods of time.
Blog post about it: https://electronicmercenary.wordpress.com/2018/03/28/the-goblet-of-fire/
Designed in Fusion 360, machined in a cheap 3020cnc machine.
Completed:
Also, custom machined fittings, because yes:
Gatekeeper.
05/06/2018 at 17:34 • 0 commentsAdding a pneumatic HVAC valve to the mess.
The cheapest HVAC valve I could find was pneumatic, so a miniature compressor and associated paraphernalia have had to be added to operate it.
Blog post about it: https://electronicmercenary.wordpress.com/2018/05/06/gatekeeper/
Thunderdrome 2
05/01/2018 at 14:16 • 0 commentsAdding the current limiting resistor, HV voltage divisor and proper cable routing to the outside of the case.
Blog post about it: https://electronicmercenary.wordpress.com/2018/05/01/thunderdrome-2/
The Colour of Magic
04/29/2018 at 19:51 • 0 commentsIs white Argon plasma. XD
Finally!
Achieved decent copper deposition!Blog post about it: https://electronicmercenary.wordpress.com/2018/04/29/the-colour-of-magic/
Doc Ock (part 2)
04/28/2018 at 09:50 • 0 commentsTesting the magnetic linkage:
(Blog post with more details: https://electronicmercenary.wordpress.com/2018/04/28/doc-ock-part-2/ )
Toolroom of Hell (part 1)
04/26/2018 at 20:46 • 0 commentsMaking the tools to make the tools. XD
Since the semiconductor tubular oven has a very particular shape, special tools are needed to bring the Alumina bricks to shape.
Extended blog post about it: https://electronicmercenary.wordpress.com/2018/04/26/toolroom-of-hell/Video for the lazy ones. XD
