The dial and code is working!
04/09/2018 at 06:39 • 0 commentsAs Borat would have said, Great Success!
Firstly I had some trouble with decoding the signal from the rotary dial. It triggered the interrupt function (ISR) in the code in weird ways. The principle behind the rotary dial is that you wind a spring up when you turn the wheel and when you release the spring pulls the dial back. On the way back there is a breaker inside the mechanism that makes a connection everytime you pass a digit. So for example an 8 would be a squarewave-package with 8 falling edges (starting and ending in HIGH, in my case 5v).
As you can see on the picture here the bounce was clear when showed on the scope:
It was solved with a software debouncer.
I then was able to read the digits and write code for dialing a code.
There is still a lot of improvements needed in software for special cases and so on but this is the first time I can enter a code and make the box open.
The sequence below goes like this:
- Log any digit entered
- If there has been 4 digits entered, check if those 4 is the correct code
- if yes, open the box
- then leave the box open until you push the "edject" button
- close the box
- reset the code -
Bells (and no whisels)
04/06/2018 at 23:50 • 0 commentsI figured part from the box just opening when you enter the correct code I also wanted some sound. To keep the vintage feel it needed to be a bell of some sort. I had some solenoids and bells from old phones lying around end tried the out.
Since I didn't want to bother with an H-bridge for the phone assembly seen below I combined a loose bell I had with a solenoid that actuates from DC pulses (polarity agnostic) and then springs back. This little contraption (now mounted on a board) also ensures that I get only one singe "bing" wich is what I want. Now I can drive this with one or two channels from the steppers darlington array (I'll have some channels/transistors to spare).
The ringing keeps going for a good while! -
Glue and Endstoppers
04/06/2018 at 23:37 • 0 commentsA few things happened today.
I installed end stoppers for the motor. They are the same kind you would find in a 3D printer (by makerbot), There are two end stoppers, the open position one is barely visible. Here you can also see the stepper motor. It's an old variable reluctance stepper and can therefor be run with a darlington array from 24V.
Once the breakers were in place I glued the plate to the metal box using epoxy.
After crimping all the wires I made as tube socket replacements I glued the whole tube assembly as well. They are held in place by vulcanizing rubber to an aluminum rod. -
Getting the Mechanics Together
04/06/2018 at 20:25 • 0 commentsThis is a video of the opening mechanism. The box and all the tubes are temporarily fastened with the black gunk you see around the tubes. It is some sort of industrial blu-tak (very sticky but never solidifies or dries, I got it from a friend working with carbon fiber).
Also here the dial is not connected and I'm manually engaging the opening mechanism. Just to get a sense for how the end result will be. It is very noisy when opening I noticed. -
Frying ICs and getting things to Glow
04/03/2018 at 20:00 • 0 commentsDid some work on getting the IN-4 tubes to glow via two shift registers. After connecting everything I realized I somehow managed to fry 4 of my K155ID1 ICs. It took a while to figure out that they were damaged. I had one left to get the setup running.
Since I don't have the original sockets I've had to make my own, I found a bunch of female connectors that I could solder onto the green wires. I also marked all the numbers. Since I chose not to mount the tubes straight onto a PCB I had a hard time making a holder for them. I eventually settled for vulcanizing rubber and a metal framework.
That was all for today, I did already order new K155ID1:s and while waiting I'll continue on the hardware side.
