Robust Big Piezo Button
A Robust Diy Button, Nearly Indestructible
It seems that people are interested in these buttons, so I made a project description just for them. For a project I need a few robust buttons. I could not find buttons in a certain size, so I decided to create my own.When you push or tap the front side of the button, you will get an impulse of +-1sec.The piezo will generated a small impulse, which is amplified by a transistor. A Ne555 in monostable mode gives me a 1sec impulse.
This Button was created for a Project for my son. Each time you touch the front of the button or tap against it, you will get an impils of 1sec. You can change the length of the impuls, by changing the capacitor and the resistor of the timer cirquit. It is also a solution to use these buttons for older peoples or for People with disabilities.
piezobu.zip
The Gerber files for the Button
x-zip-compressed - 37.17 kB - 05/03/2016 at 05:59
Download
taster2.dch
The PCB in Diptace
dch - 71.66 kB - 05/03/2016 at 05:58
Download
taster02.dip
The shematic file in Diptrace
dip - 93.87 kB - 05/03/2016 at 05:58
Download
  • 1 × 55mm Pipe Stop End
  • 1 × Ne555 Discrete Semiconductors / Power Transistors and MOSFETs
  • 1 × BC548 Discrete Semiconductors / Transistors, MOSFETs, FETs, IGBTs
  • 2 × 10K Resistor
  • 1 × 330R Resistor Electronic Components / Misc. Electronic Components
View all 11 components
View all 4 project logs
  • 1
    Step 1
    Test Setup
  • 2
    Step 2
    The housing for the button
    I used a 55mm Pipe Stop End. I sand the piece to remove the irregularities.
    In the pipe stop end, I glued a 35mm Piezo element inside it with epoxy glue
  • 3
    Step 3
    The PCB
    Because I need about 6 buttons, I decided to create a PCB.
    I used DipTrace for the layout, and I ordered them at http://www.pcbway.com/
View all 5 instructions
Gabriel wrote 05/04/2016 at 04:26 point
brilliant!
