20180416_190037.jpgTop view.JPEG Image - 3.16 MB - 04/16/2018 at 23:11 |
20180416_190004.jpgThe small model in front.All together Air Pressure Quadcopter. All wires, motors, fans, controls, servos, and battery inside. Unit has been taped up the final will be glued and sealed at tight as possible. JPEG Image - 2.76 MB - 04/16/2018 at 23:08 |
20180416_123906.jpgWiring charging connection will be the only wires showing on the bottom outside of unit.Connecting top duct and wiring together. Close unit up. JPEG Image - 2.74 MB - 04/16/2018 at 16:59 |
20180416_091834.jpgConnecting wires together from bottom of unit up.Battery wire Motor wire JPEG Image - 2.76 MB - 04/16/2018 at 16:56 |
20180415_151712.jpgBroken down.Prepare for inside wiring. JPEG Image - 3.05 MB - 04/15/2018 at 19:30 |
20180415_145929.jpgTop view all together.Two propellers on two off. JPEG Image - 2.93 MB - 04/15/2018 at 19:29 |
20180415_124830.jpgAttach propellers.Next work on closing up box. JPEG Image - 5.18 MB - 04/15/2018 at 16:54 |
20180415_124629.jpgApply the spacers to each rod.While setting the fan in the right position. JPEG Image - 4.40 MB - 04/15/2018 at 16:53 |
20180415_124636.jpgAll four rods set into place.JPEG Image - 5.47 MB - 04/15/2018 at 16:52 |
20180414_222617.jpgTubes connected to fan box. Working on setting the rods next.JPEG Image - 3.17 MB - 04/15/2018 at 03:35 |
20180414_221634_001.jpgFan box assembled.JPEG Image - 2.34 MB - 04/15/2018 at 03:34 |
20180414_210131.jpgFan box. All pieces.JPEG Image - 5.36 MB - 04/15/2018 at 03:33 |
20180414_210156.jpg3d printed fan box.JPEG Image - 4.13 MB - 04/15/2018 at 03:32 |
20180412_112459.jpg(Top view) weighs 10.0 ozJPEG Image - 3.65 MB - 04/12/2018 at 15:56 |
20180412_112432.jpg(All together)Front view no wires attached. Built up Just to get a good look. All wires will be inside unit.JPEG Image - 2.13 MB - 04/12/2018 at 15:27 |
20180412_095913.jpgInstalled Control Module inside top duct vent.JPEG Image - 2.84 MB - 04/12/2018 at 15:26 |
20180411_223737.jpgAttached motors to ducts.JPEG Image - 2.44 MB - 04/12/2018 at 15:25 |
20180411_211739.jpg3d printed fan attached to motor.JPEG Image - 3.12 MB - 04/12/2018 at 15:23 |
20180410_101710.jpg(Side View)JPEG Image - 2.73 MB - 04/10/2018 at 14:43 |
20180410_101610.jpg(Front View) 3d printed and attached arm supports to unit. Also attached tubes to see how it looks.JPEG Image - 3.37 MB - 04/10/2018 at 14:40 |
20180409_134841.jpgSo far 6.8 oz.. unit together.JPEG Image - 2.72 MB - 04/09/2018 at 17:49 |
20180409_133853.jpgLooks like motion design fits.JPEG Image - 2.98 MB - 04/09/2018 at 17:39 |
20180409_132821.jpgAir Pressure Quadcopter Unit.JPEG Image - 2.63 MB - 04/09/2018 at 17:30 |
20180409_130338.jpgMotion installed inside Air Distributor Duct.JPEG Image - 2.18 MB - 04/09/2018 at 17:10 |
20180409_125401.jpgMotion (Forward/Backwards Left/Right) 3d printed and connected to Servos.JPEG Image - 3.54 MB - 04/09/2018 at 17:08 |
20180409_094958.jpgThis is how the Air Pressure Quadcopter Unit looks together. (Rubber band is just to hold together)JPEG Image - 3.12 MB - 04/09/2018 at 14:10 |
20180409_094914.jpgThis is a picture of the 3d printed Air Pressure Quadcopter Unit spread out across top. Motion controls also printed. Along bottom motors, servos, battery, control module, tubesJPEG Image - 5.09 MB - 04/09/2018 at 14:05 |
20180407_200849.jpg3D printing Top Duct Vent SystemJPEG Image - 2.86 MB - 04/08/2018 at 01:52 |
20180406_224128.jpgMiddle Duct finished.JPEG Image - 2.58 MB - 04/08/2018 at 01:51 |
20180406_212303.jpg3D Print Middle DuctJPEG Image - 2.11 MB - 04/08/2018 at 01:50 |
