Grow-IoT
An extensible, open source IoT stack for smart control systems.
ajaysankar wrote 09/24/2019 at 14:40 point
I am using MSP430 to know the status of temperature in industrial areas with low power Microcontroller .
I tried to write the code using energia platform flame sensor using RTOS Environment and push the data to cloud (to observe the output in the displays)
I am trying to upload the code with Arduino UNO but the code was not supporting as per Arduino Instruction set
I bought the controller at
http://bigbelectronics.in/product.php?product=m430g2452-mixed-signal-microcontroller
you can check the specs
