EMULPC.EXEExecutable file for Windows, 32-bit OS onlyx-msdownload - 134.43 kB - 06/20/2016 at 20:47 |
EMULPC.ASMSource fileasm - 25.21 kB - 06/20/2016 at 20:47 |
obj - 6.41 kB - 06/20/2016 at 20:47 |
set - 86.00 bytes - 06/20/2016 at 20:47 |
EMUL_eng.ASMEMUL.ASM with comments translated to Englishasm - 8.93 kB - 06/20/2016 at 20:47 |
map - 323.00 bytes - 06/20/2016 at 20:47 |
EMUL.ASMAssembly language source file for EPROM emulator. This file dates from the early '90s, so its mnemonic is not compatible with the new IDE (MPLAB or MPLABX)asm - 8.93 kB - 06/20/2016 at 19:41 |
PICREG.EQUINCLUDE file with register definitions for PIC5x MCUs. Note that it contains only 31 definitions!equ - 801.00 bytes - 06/20/2016 at 19:41 |
