CFL 6500K 23W/120VAC
A project log for DAV5 V2.1 Spectrometer
The ZEN of simplicity Making the Complex...Seem Simple
David H Haffner SrDavid H Haffner Sr 01/07/2018 at 21:397 Comments
01/07/2018 4:39:PM
Ted Yapo wrote 01/07/2018 at 21:55 point
What's that little dip in the peak near 546nm?  Are there two mercury lines there?
David H Haffner Sr wrote 01/07/2018 at 23:40 point
Hey Ted, yes it is, but its not one of the calibration points, the peak though is 542nm, I'll put up another RSpec plot with reference lines for Mercury that will show exactly where the element peaks are at.
David H Haffner Sr wrote 01/07/2018 at 23:53 point
I just posted an updated plot showing the HG (mercury lines)
Ted Yapo wrote 01/08/2018 at 00:03 point
Thanks! I knew there was a double line in the yellow, but never noticed two in the green before.
That's really good.  Can you verify/estimate that this spectrum is close to a 6500K color temperature?
David H Haffner Sr wrote 01/08/2018 at 00:08 point
Yeah I can Ted, I'm still trying to figure that part out in this program, getting the hang of it :)
Dr. Cockroach wrote 01/07/2018 at 21:49 point
That is so cool and it's art as well :-)
Hello good Dr. :)
It does look pretty doesn't it?
