154-Analysis of Visible Light Communication System for Implementation in Sensor Networks.pdfVisible Light Communication technology today provides an opportunity for high speed and low cost wireless communication.In this paper, we give solution based on our research, relating to the VLC application in sensor networks in IoT systems. Adobe Portable Document Format - 753.52 kB - 07/07/2016 at 02:43 |
Model multikanalne VLC opto-telekomunikacije razvojnih SoC i IoT senzorkih sistema-RC2.pdfModel of multi-channel VLC opto-telecommunications between the SoC development and IoT/sensor systemThis work is a continuation of research in the field of analysis, modeling and establishing an optimal model PAN VLC opto – telecommunications between SoC development computer, micro-controllers, IoT and sensor systems. The work presents the concept and design solutions of receive – transmitting electronic circuits intended to establish peer – to – peer communication over short distances between devices with high energy efficiency. A large number of such devices in a relatively small area is somewhat of a challenge when we consider the expectations for these devices operating in the available classic transceiver ISM RF fields, currently available, on the other hand the width of the available range of the light part of spectrum represent a huge potential. Adobe Portable Document Format - 902.79 kB - 07/07/2016 at 02:40 |
