TIS-100 is a puzzle game that requires the player to write assembler code. The instruction set is limited, little is known about the emulated system that is the core of the game.
What's knowns however is that there is at least one instruction which is not documented.
Whenever the player enters an wrong command a red error message pops up. The facts that the message is shown right after Input and that all instructions are all three characters long will be exploited in this project.
The purpose is to enter every possible string that may or (way more likely) may not be a command into the game and check for errors. Automatically, of course.
That took longer than expected. TIS-100 failed to recognize the backspace presses during the first test. That could be cured with some extra delay after each keystroke.
What turned out to be quite annoying is that TIS-100 is prone to crashing after a few hours on my machine. This is rather annoying since I am running the acquisition of screenshots over night just to find out that instead logging everything from AAA to ZZZ the process stopped working at e.g. FTM.
Furthermore there are some wrong screenshots every so often, probably because a spike in the system load prevented a clean execution of all the keystrokes (I'm looking at you, Windows updater...).
Anyway, the screenshots are acquired. At least hopefully, there might be some irregular entries. I will have to sort that out during the octave analysis.
It is really simple: the game accepts three character long inputs as commands. 15 instructions are documented int the TIS-100 datasheet (the game's manual).
So there are 26*26*26 = 17576 possible combinations which may or may not be a legal command.
The plan is to use an Arduino Leonardo in HID mode to enter all these combinations, a blank right after a combination followed by F12 (the hotkey for screenshots). I allow the game a pause of 200 ms after entering the blank to bring up the error popup that is shown whenever the input is not a known command. And another 500 ms delay to allow the system to take the screenshot and save it.
It should take roughly four hours to complete the cycle.
To avoid having to look though all 17576 screenshots by myself I will use GNU-octave to look through the images and search for the red error message. Every image without this message contains a command. So there should be at least 16 (it is known that there is at lease one undocumented command).
