I basically just made a clock thats faces moves instead of the hands, now in no way is this more conventional than a normal clock however its cool looking and fun to make (i used an Arduino instead of a 555 timer because i play to add more features)
Details
My code works with a clock face with a circumference of 72 cm now you could make it larger or smaller but you would have to adjust the code
good
