This is for the large blue box version of the YOOCNC 3020/6040, since it fits in the existing PCB stand offs and uses the same connectors.
I added inputs for limit switches etc, so they just have to be run around the machine and a few micro switches added to gantry, you can also use it to add a home feature.
I'm in the final stage testing of it, i totally missed adding a power section to the CPU on the current rev and the CPU would reset when the head was loaded, so i redid the power section to make it beefier and have a better, smoother power supply for the CPU. since it all runs off the 24V out of the CNC, it dropped down way too much and browned out.
It's mostly grbl with a few changes here and there, similar to the JUKI PNP I did.
But cutting softer materials , its fine. Next revision board is prepped to be sent in and built.
charliex
Patrick
Miroslav Zuzelka
MagicWolfi
+1 for the buried Matt Foley reference...."...living in a (cara)van, down by the (river)!!".
