Schematic.pngCircuit design of OwliePortable Network Graphics (PNG) - 79.25 kB - 09/18/2016 at 21:12 |
Testing of Owlie.m4vOwlie beeps from the buzzer and vibrates from the pager motor only once between 150 cm and 100cm from an object to let the user be aware of an object in that distance. As the object gets closer between 100cm and 30 cm, it beeps and vibrates more frequently about 5 times. Then when it gets too close less than 30 cm, it keeps beeping and vibrating until the user moves away from the object.MPEG-4 Video - 26.44 MB - 09/18/2016 at 19:41 |
