ATX Benchtop Power Supply
Back to overview
Need a low-accuracy, high-noise, obscene-current benchtop supply? Build this with junk from your basement!
WorkstationUser wrote 08/03/2016 at 09:54 point
Thanks for the guide!
Regarding Step 12:  "I'm running a bunch of 2-watt resistors in parallel; remember, wattages stack in this configuration if the resistance values are the same."
The effective resistance of a bunch of resistors in parallel is
    R_effective = 1 / ( 1/R_1  +  1/R_2  +  1/R_3 + ...  + 1/R_n ),
or just
    R_effective = R_common / number
if they all have the same resistance.
Then, each resistor gets part of the current, with a share equal to 1/R_i.  For example, if all resistors have the same voltage, then they split the current evenly (in theory).  Or if there's a 1-Ohm and a 2-Ohm, then the 1-Ohm gets twice as much current as the 2-Ohm.
