Adobe Portable Document Format - 8.82 MB - 10/27/2021 at 03:32 |
Portable Network Graphics (PNG) - 20.71 kB - 12/04/2018 at 05:04 |
Open Source Fist.svgSeize The Memes Of Production!svg+xml - 6.23 kB - 12/04/2018 at 05:04 |
Flake Extruding Print Head SketchUp Model- V1 9-29-18.skpMost current 3D model of flake extruding head I'm using on the MPCNC. So far, I know it works, in that it extrudes a consistent bead of plastic (currently PP, #5) in response to computer control of the stepper motor. Many improvements can (and will) be made to this design, but it's low cost, easily sourced parts, and good-enough performance warrant documentation. This model is MOSTLY to scale, but not in any technical way, so go by the stated measurements, rather than the model measurements, and make sure to check everything against what you can actually find at your local hardware store.SSEYO Koan Play File - 4.74 MB - 09/29/2018 at 22:29 |
MostlyPrintedCNC 25.4mmOD.zipAll 3D print files for building the MPCNC with exactly 1" (25.4mm) OD stainless steel or aluminum tubing (NOT for conduit)Zip Archive - 3.98 MB - 09/28/2018 at 18:56 |
MostlyPrintedCNC 23.5mmOD.zipAll 3D print files for building the MPCNC with 3/4" EMT Conduit, which has an OD of 23.5mm (almost 1"). Bring calipers to the hardware store to be sure.Zip Archive - 4.72 MB - 09/28/2018 at 18:56 |
Precious Plastic Machine Files.zipAll files required to build Precious Plastic recycling machines.Zip Archive - 36.82 MB - 09/28/2018 at 18:55 |
