We will have a tube attached to container filled with a cooler. Air will be pushed through the container by a ventilator. And using an infrared emitter and captor the tube will follow your presence qround the room through a 180 degree angle of mouvement
We recieved very few of our components today. We managed to get our IR emitter working. We are still looking for the main part of the cooler build. We are starting to work with the arduino programming research
