All of the documents about the MC60 that I could get from the Quectel website are posted in the Git repo at : https://github.com/wyolum/MC60/tree/master/data/MC60_data
Quectel MC60
Power Input is 5V / 3 Amps, but a 2 Amps source might work.
Connectors and Interfaces
- 3.5mm audio jack, CTIA style TRRS (Left/Right/GND/Mic)
- Micro SD Card socket
- Micro SIM socket
- u.FL connector for GPS Antenna
- u.FL connector for GNSS Antenna
- On board Chip Antenna for Bluetooth
- On/Off switch (or via external signals)
- External 3V3 input. 3 pin header (GND/3V3/GND), to prevent reverse connections)
- 3V3 or 5V selector for UART output connector voltage.
- 8-pin UART header. MC60 communicates with external world via this header
- 3 pin Debug UART
Status
- Hardware : Design is complete.
- Gerbers : Not yet generated pending design review.
- Software : None
Anool Mahidharia
This is amazing project. I loved it. This is exactly what I was looking for.
https://www.hebpartnernet.org/
