My idea is to put inside an small package of the classic Tic Tac hard mints an Arduino Nano, an 0.96" OLED display, an AAA battery, and a step-up module to convert the battery 1,5V to 5V.
The display is 128x64, the pixels of the first 16 lines are yellow and the 48 bottom lines are blue.
The first game will be a version of Breakout (aka Arkanoid), as shown on the picture.
So far, the power consumption is under 30mA, so the AAA battery may have a decent life (I hope).
Components
1×
0.96" OLED SPI display for arduino 128x64 pixels
https://www.aliexpress.com/item/Free-Shipping-1Pcs-Yellow-blue-double-color-128X64-OLED-LCD-LED-Display-Module-For-Arduino-0/32233300972.html?spm=a2g0s.9042311.0.0.27424c4dv6cSFO
1×
Breadboard for development
https://www.aliexpress.com/item/FREE-SHIPPING1pcs-Breadboard-830-Point-Solderless-PCB-Bread-Board-MB-102-MB102-Test-Develop-DIY/32252670652.html?spm=2114.search0104.3.1.31484afcSKiTeL&ws_ab_test=searchweb0_0,searchweb201602_2_10152_10151_10065_10344_10068_5722815_10342_10547_10343_10340_5722915_10548_10341_5722615_10696_10084_10083_10618_10307_5722715_10059_100031_10103_10624_10623_10622_5722515_10621_10620,searchweb201603_25,ppcSwitch_5&algo_expid=dfdd5dfe-f430-4fcc-8668-bf4b92ceea12-0&algo_pvid=dfdd5dfe-f430-4fcc-8668-bf4b92ceea12&transAbTest=ae803_1&priceBeautifyAB=0
1×
Male to male jumper wires
https://www.newegg.com/Product/Product.aspx?Item=9SIA7BF34K5877
- I could put all circuits inside the Tic Tac case;
- Small update in software. The minimum viable game is done.
Next steps:
- Circuit to measure the batteries power level. It may show a small icon on top of the screen, just like an smartphone;
- More buttons (all four directions, plus two action buttons);
- Transparent case would be more cool than this orange partially transparent;
- Back light (is it really needed?). The 5110 display has this feature, but I'm not using for now, because of power saving reasons;
-Software reset (pressing the two buttons for 3 seconds). There is already a Hardware Reset: a small hole in the case's back to press the Arduino reset button;
- More than one game pre-loaded (I'm not sure if the small memory of Arduino Nano would be enougth).
- Many other things that I don't remember right now.
After various problems I decided to put the components together using a universal PCB, both for electrical contacts and mecanical suport for them.
Many changes since the original idea (I will update the components list later):
Now I'm using the 5110 LCD display (same as the old Nokia phone), and my idea is to use a CR2032 coin battery, with a step-up module to convert the 3V of the battery to 5V necessary for Arduino.
At least for now, there will be only 2 buttons (Left and Right), for sake of simplicity.
I managed to soldering the Arduino, display and the buttons in the PCB. Besides this I wrote a very crude first draft of a breakout game. This took me aproximatelly 2 hours of work, which seems very good for me.
Next step is connect the power (Battery and step-up module), sound (a simple buzzer), and fit everything inside a TicTac plastic case.
Some pictures of the progress so far (probably the worst soldering you have ever seen):
