topFrame.stl
for PULSE PACK enclosure
Standard Tesselated Geometry -
367.56 kB -
10/21/2018 at 23:40
Download
Harness_Adaptor.stl
104.77 kB -
10/21/2018 at 23:39
Download
bottomFrame_inside.stl
132.70 kB -
10/21/2018 at 23:39
Download
Base_1.stl
277.04 kB -
10/21/2018 at 23:38
Download
harnessMounts.stl
218.25 kB -
10/21/2018 at 22:59
Download
Joint_bottom.stl
49.79 kB -
10/21/2018 at 22:59
Download
bottomFrame.stl
435.92 kB -
10/21/2018 at 22:59
Download
port.stl
497.05 kB -
10/21/2018 at 22:59
Download
heart_Bracket.stl
40.61 kB -
10/21/2018 at 22:59
Download
washer.stl
38.17 kB -
10/21/2018 at 22:59
Download
heart_Bracket_long.stl
32.80 kB -
10/21/2018 at 22:59
Download
Base_3.stl
118.15 kB -
10/21/2018 at 22:59
Download
Base_2.stl
184.55 kB -
10/21/2018 at 22:44
Download
heartSpacer.stl
58.97 kB -
10/21/2018 at 22:44
Download
portNut.stl
119.61 kB -
10/21/2018 at 22:44
Download
Joint_top.stl
96.47 kB -
10/21/2018 at 22:44
Download
shebon_heart.brd
PULSE PCB : EAGLE design file
brd -
181.69 kB -
10/21/2018 at 21:35
Download
shebon_heart_schematic.pdf
PULSE board schematic
Adobe Portable Document Format -
106.79 kB -
10/21/2018 at 21:35
Preview
pulsePCB_Gerbers.zip
PULSE gerber files
Zip Archive -
579.92 kB -
10/21/2018 at 21:35
Download
pulsePCB_BOM.txt
PULSE PCB bill of materials
plain -
6.30 kB -
10/21/2018 at 21:35
Download
face_plate.stl
POPgirl face plate
365.12 kB -
10/20/2018 at 17:07
Download
arm_mount.stl
POPgirl arm plate
272.64 kB -
10/20/2018 at 17:07
Download
2mm_spacer.stl
POPgirl 2mm spacer
35.04 kB -
10/20/2018 at 17:07
Download
17mm_spacer.stl
POPgirl 17mm spacer
58.09 kB -
10/20/2018 at 17:07
Download
PCB_mount.stl
POPgirl PCB mount
130.36 kB -
10/20/2018 at 17:07
Download
screen_capture.stl
POPgirl screen capture
114.54 kB -
10/20/2018 at 17:07
Download
gasket.stl
POPgirl screen gasket
60.63 kB -
10/20/2018 at 17:07
Download
5_5mm_spacer.stl
POPgirl 5.5mm spacer
50.18 kB -
10/20/2018 at 17:07
Download
3mm_spacer.stl
POPgirl 3mm spacer
34.65 kB -
10/20/2018 at 17:07
Download
