Arduboy MAX
using a 2.42" OLED display and Game Boy buttons with a diy board around the atmega32u4
work in progress
I would have preferred to use one of the many spare arduino pro micros, but the arduboy gang used pins that aren't broken out on. So I've bought 2 TQFP atmega32u4 chips and started to design a board.
View all 2 project logs
Hendra Kusumah wrote 06/10/2018 at 21:24 point
Oh yeah btw, Loving this arduboy XL project :).
Hendra Kusumah wrote 06/10/2018 at 21:22 point
There is an alternative bootloader if you want to stick with pro micro. And I think pro micro pins is already capable if you don't use the RGB led.
https://github.com/MrBlinky/Arduboy-homemade-package
davedarko wrote 06/11/2018 at 07:27 point
hm, the pinout of the SPI display uses pins (CS, DC) that aren't broken out on the Sparkfun pro micro I have. The goal is having the same experience without "tinkering with bootloaders". But thanks a bunch for the link, might come in handy if it doesn't work the way I thought! :)
deshipu wrote 06/10/2018 at 19:38 point
Have you considered a teensy 2 or a-star mini? The latter has interesting colors too! (and no, I'm not saying you should use them, making your own is much cooler)
davedarko wrote 06/10/2018 at 20:20 point
oh you mean to check if all the pins are broken out? I could check that on a teensy, good idea, thanks!
