RESTful smart power plug
Back to overview
An open communication protocol smart power plug
IT-Wizard wrote 06/28/2018 at 11:53 • point
Sweet! I may inspire myself of that project. I just need the addition of a switch for manual operation also.
Ricky Zhang wrote 06/29/2018 at 01:10 • point
If you crank that physical manual switch into smart power plug, you may force yourself into a dilemma: should they be in series connection or parallel connection... I'd recommend to build a separate power switch with ESP8266 to turn on/off through REST call.
Ricky Zhang wrote 07/20/2018 at 14:36 • point
Well, I have a second thought on adding a switch. I may add a momentary switch and hook up to ESP8266 GPIO to toggle on/off as well. My previous idea sucks. I will try it on once I got the parts.
Ricky Zhang wrote 05/26/2020 at 13:40 • point
I enabled a physical button switch in Sonoff S20. Go check out my new project log. I updated firmware.
