What if ferrofluid can be moved around with a simple PCB? This is what this project is all about! <br><br>Inspired by,<br><a target="_blank" rel="noopener noreferrer" href="https://hackaday.com/2015/08/18/ferrofluid-clock-is-a-work-of-art/">https://hackaday.com/2015/08/18/ferrofluid-clock-is-a-work-of-art/</a><br><br>And my other PCB coils project, <br><a target="_blank" rel="noopener noreferrer" href="https://hackaday.io/project/158017-linear-pcb-motor">https://hackaday.io/project/158017-linear-pcb-motor</a><br><a target="_blank" rel="noopener noreferrer" href="https://hackaday.io/project/39494-pcb-motor">https://hackaday.io/project/39494-pcb-motor</a><br><br>I'm hoping to try and make ferrofluid dance around with just PCB coils.
Today i have ordered some new test boards with a total of 9 pcb coils. These have different turns, and three of these coils also have a 5mm diameter hole in the middle to test them with an iron core. This should increase the magnetic field of the windings and attract stronger the ferrofluid.
The magnetic field of the windings need to be a little stronger but the concept seems to be working.
The idea is to have ferrofluid dancing around from a simple PCB. This is obviously just a concept but with more windings and perhaps with a core in the middle of these printed windings, it can be possible. (Also, I need to find a way not to stain the container with the ferrofluid .. its a little messy)
This was tested with my open source Linear PCB Motor board:
This is really cool. I have always wanted to play around with ferrofluid, and this project led me down a PCB coils rabbit hole. :P
