Rev.10 Update Log
07/10/2018 at 17:53 • 0 commentsThis time the updates are slow but important.
- Added charging pad for ease of use (Read the warning on Cmts.User)
- Daughter board now has less copper to aid in signal loss reduction
- Added Noncommercial symbol
- Added graphic
- Component orientations are now marked with dots (Read the Cmts.User layer)
- Via stitching done (forgot to add that to Rev.9)
Daughter board has footprints but don't populate them! They are there as a decoration. You can see how the circuit makes absolutely no sense whatsoever, with it disregarding design rule like you drink water.
Now, all I have to do is have this tested somehow...
Revision 9 Update Log
07/10/2018 at 17:45 • 0 commentsGoing fast again!
- Fixed copper fill freeze - 989 zero-size stacked segments somehow got inserted into the Edge.Cuts layer.
- Added ornamental daughter board to prevent accidental shorts
- Added graphic
- Added explanations
- Added cyberpunk vibe
Drama over, back to work again
07/09/2018 at 17:49 • 0 commentsApparently due to some unknown reason KiCad wrote several hundred of zero-width tracks that point to the same place, causing the algorithm to spiral out of control. Removing those lines has made the fill work again.
Evidence #1: Text log of the crime
After all the drama...
07/09/2018 at 15:38 • 0 comments...It just tossed me back the unchanged PCB with no GND nets connected. Why you do this, KiCad?!
Well, shoot.
07/09/2018 at 15:13 • 0 commentsIt's stuck there for 6 hours now.
Rev.8 Update Log
07/08/2018 at 16:32 • 0 commentsSlowing down...
- Wired up all components
- Fixed minor mistakes
- Made polygons for copper fill (May be replaced with square if problem persists)
Rev.6 and Rev.7 Update Log
07/08/2018 at 13:37 • 0 commentsGoing fast now:
- LED footprint association fixed (5050 -> PLCC-2)
- Motor connector footprint association fixed (SMD Resistor -> Pin Header)
- Done component organization
- Redone component organization
- Net cleaned up (No more global tags for power)
- Track width modified for Vcc, GND, LED, +BATT and -BATT
- Removed SPI header
- Jumper type changed (NC -> NO)
- Jumper footprint association fixed (Pin Header -> Jumper Pad)
- GPIO0 and GPIO2 now uses separate wire
- LED current limiting resistor value changed
- Keepout zone added for ESP-12F
- Moved LED and other switched components away from antenna
- Added logo
- Added logo again
- Added branding
Rev.5 Update Log
07/07/2018 at 16:41 • 0 commentsA lot of changes happened on this version:
- Added logo
- Added front silkscreen graphic
- 5050 LED replaced with PLCC2 LED
- Board outline added (TODO: Add tabs for panelizing)
- Initial component cramming done (Unrouted!)
- Background assets done
- Currently deciding between using ESP-03 and ESP-12F
- SPI header may disappear in the future
- Motor header type changed
- Added LED eyes
- Please don't sue us I love you CDPR xoxo
Update round-up #1
07/06/2018 at 10:02 • 0 commentsUpdate round-up (rev.1 ~ rev.3):
- Added LEDs
- Layout changes
- Added WAKEY switch
- Removed WAKEY switch
- Added WAKEY jumper
- Added DW01 battery protection IC (power source is not confirmed yet)
- Changed NPN Transistor to N-channel MOSFET
- Added SPI pad
- Added UART pad
- Added voltage regulator
- Cleaned up unused parts
- Updated power supply section with reference design
- ESP8266 module changed from ESP-02 to ESP-12F
