YAPR
Yet Another Pick and place Robot
Trying to build my own PnP machine to see if I can do it. Should be able to be used as easily as a 3d printer.
I'm trying to build a production-ready pick and place machine for prototyping and small production runs. The goal is to have the components loaded in the feeders all the time, so populating a new design is just a matter of sticking the boards in and uploading the pnp file. I normally try to use standard parts and to reuse most of the parts in my new board designs, so the number of different components should be manageable. The current plan includes space for 72 feeders (8mm, https://docs.mgrl.de/maschine:pickandplace:feeder:0816feeder), which should last me for a long time. If I ever need more space, I can move the side rails outward and make the machine up to 2m wide. It should also be possible to add a second gantry for twice the speed. The thing will be driven by NEMA23 stepper motors, which I have lying around. In the future, I might swap them out for brushless DC servo motors (https://odriverobotics.com/ seems promising).
  • Day 3: Y Axis
    Christoph07/30/2018 at 17:00 0 comments
    To conceal the rough ends of the rails, I covered them with printed end caps, which also act as belt tensioners. The belt brackets are fastened to the end caps and tightened using M3 screws. Afterwards, I fixed them to the rails with more M3 screws to take some of the stress off the caps.
    For testing, I connected the stepper motors to an Arduino CNC shield and tested out different speeds and accelerations. Sadly, the limit seems to be around 100mm/s, which is really, really slow for a PnP machine. Changing the Y axis to servo drive will be one of the first upgrades after everything else is working.
    I'm already thinking about building my own BLDC servo using a standard 2212 motor with a printed encoder. If it works, it should allow the heads to move up and down fast enough. I need to continue with the head design now before going any further with this build, because the head will determine which motors I can use on the X axis.
  • Day 2: Gantry
    Christoph07/18/2018 at 17:46 0 comments
    The y carriages came out of the 3d printer and they fit to the rails almost perfectly. I'm very lazy, so I made the carriages so they fit tightly around the ends of the rails, thereby covering the ugly hand-sawn ends. They are firmly held in place by M3 screws. The ball bearings roll over the y rails smoothly enough, though I have discovered that even a small piece of dirt makes the wheels slide instead of spin. I guess I'll have to keep the rails clean.
    The gantry is driven by one NEMA23 motor at each end. The beauty of this design is that the gantry will align itself automatically to be square to the base as long as the endstops are mounted accurately (and the motors don't lose steps, which would be bad anyway). I only have to add one bearing to each side to keep the gantry from sliding left to right. One of these bearings will be mounted firmly to the carriage, while the other will be pushed against the rail to eliminate clearance.
    The next step will be to attach the GT2 belts to the y rails and make the gantry move on its own.
  • Day 1: Base
    Christoph07/15/2018 at 16:33 0 comments
    I went shopping for parts yesterday, and returned with a base plate which was a bit larger (but much cheaper) than I had intended. As I can't use a circular saw in my apartment, I just updated the design to use a larger base (more feeders, yay!). I manually cut the side rails, which are 50x20mm extruded aluminum, and screwed them to the base using M5 bolts. The distance between the outer edges is 709mm now and they overlap the base by about 16mm on each side.
    I also tested the design for the Y carriages, which are 3d printed in PLA and run on skateboard bearings. I think I have a working design now, but I'll know for sure when the gantry is rolling on the rails (hopefully tomorrow).
View all 3 project logs
