SK000002
12/07/2018 at 14:15 • 0 commentsPCB coil joule thief has now officially been certified as open source hardware by the Open Source Hardware Association.
new boards test
07/25/2018 at 11:39 • 0 commentsPromised new board photos ...
new layout
07/17/2018 at 21:12 • 0 commentsLittle enlarged for AA battery, LED moved to center
It is working !!!
07/16/2018 at 11:17 • 0 commentsIt can not believe, I soldered all components .... slide switch to ON and LED shine :)
All at first attempt.
Some measurements
- Input voltage 1.5V
- Startup voltage 0.5V
- Frequency 260Khz
- Input current 36mA
- Output current 5mA through LED
- Output voltage without load 20V
And last one bright photo ;-)
Uaauu boards received
07/16/2018 at 09:33 • 0 commentshuraaaa board received from factory, super speed DHL, Lets go to asemblyyyyyyyyyyyyyy !!!!!
Boards in fab ...
07/13/2018 at 21:51 • 0 commentsI am waiting on big surprise in Monday to watch if it work
Board finished
07/10/2018 at 13:12 • 0 commentsI just finished board and waiting for surprise :)
