This Tiny Joypad "Megazoid Variant" project is now complete. If anybody has any questions - ask away. Many thanks to the kind people that helped out
This might be a nice platform for people who like to write ATtiny85 games. Having the option of sound, screen rotation, and a joystick does give you a bit more flexibility over projects such as Attiny Arcade (although Tiny Joypad is a harder build).
More Tiny Joypad games, info and designs can be found on Daniel Champagne site : https://www.tinyjoypad.com
Slight code changes are needed for PacMan and Tiny Arkanoid for them to work on my version of Tiny Joypad (or just use the files in the Tiny_Joypad_Variant-Games-master.zip )
PacMan - Change
if ((analogRead(A3)>=750)&&(analogRead(A3)<950)) {Sprite[0].DirectionH=1;}
else if ((analogRead(A3)>500)&&(analogRead(A3)<750)) {Sprite[0].DirectionH=0;}
To
if ((analogRead(A3)>=750)&&(analogRead(A3)<950)) {Sprite[0].DirectionH=0;}
else if ((analogRead(A3)>500)&&(analogRead(A3)<750)) {Sprite[0].DirectionH=1;}
Tiny Arkanoid - Change
if ((analogRead(A3)>=750)&&(analogRead(A3)<850)) {if (VARIABLE.TrackBaryDecal<7) {if (VARIABLE.TrackBaryDecal+(VARIABLE.TrackBary*8)<44){ VARIABLE.TrackBaryDecal++;}}else{VARIABLE.TrackBaryDecal=0;VARIABLE.TrackBary++;}}
if ((analogRead(A3)>500)&&(analogRead(A3)<750)) {if (VARIABLE.TrackBaryDecal>0) {if (VARIABLE.TrackBaryDecal+(VARIABLE.TrackBary*8)>4){ VARIABLE.TrackBaryDecal--;}}else{VARIABLE.TrackBaryDecal=7;VARIABLE.TrackBary--;}}
To
if ((analogRead(A3)>=750)&&(analogRead(A3)<850)) {if (VARIABLE.TrackBaryDecal>0) {if (VARIABLE.TrackBaryDecal+(VARIABLE.TrackBary*8)>4){ VARIABLE.TrackBaryDecal--;}}else{VARIABLE.TrackBaryDecal=7;VARIABLE.TrackBary--;}} if ((analogRead(A3)>500)&&(analogRead(A3)<750)) {if (VARIABLE.TrackBaryDecal<7) {if (VARIABLE.TrackBaryDecal+(VARIABLE.TrackBary*8)<44){ VARIABLE.TrackBaryDecal++;}}else{VARIABLE.TrackBaryDecal=0;VARIABLE.TrackBary++;}}
* Don't forget when you program the cartridges, that Pin's 1 and 2 are swapped around on the Pacman and Tiny Arkanoid PCB's.
Thanks for sharing this amazing content. If you're Roblox game lover you can must try this game with it's Executors. There are many type of executors available in the market but my favorite is Codex Executor. You can easily download codex executor here. http://www.codexexecutors.com/
