This Tiny Joypad project is now complete. If anybody has any questions - ask away. I might do some kits, but this would be limited to the parts I have left (3 or 4 kits). Message me if you have some interest. Many thanks to the kind people that helped out
This might be a nice platform for people who like to write ATtiny85 games. Having the option of sound, screen rotation, and a joystick does give you a bit more flexibility over projects such as Attiny Arcade (although Tiny Joypad is a harder build).
The games can be found on Daniel Champagne site : https://sites.google.com/view/arduino-collection
Slight code changes are needed for PacMan and Tiny Arkanoid :
PacMan - Change
if ((analogRead(A3)>=750)&&(analogRead(A3)<950)) {Sprite[0].DirectionH=1;}
else if ((analogRead(A3)>500)&&(analogRead(A3)<750)) {Sprite[0].DirectionH=0;}
To
if ((analogRead(A3)>=750)&&(analogRead(A3)<950)) {Sprite[0].DirectionH=0;}
else if ((analogRead(A3)>500)&&(analogRead(A3)<750)) {Sprite[0].DirectionH=1;}
Tiny Arkanoid - Change
if ((analogRead(A3)>=750)&&(analogRead(A3)<850)) {if (VARIABLE.TrackBaryDecal<7) {if (VARIABLE.TrackBaryDecal+(VARIABLE.TrackBary*8)<44){ VARIABLE.TrackBaryDecal++;}}else{VARIABLE.TrackBaryDecal=0;VARIABLE.TrackBary++;}}
if ((analogRead(A3)>500)&&(analogRead(A3)<750)) {if (VARIABLE.TrackBaryDecal>0) {if (VARIABLE.TrackBaryDecal+(VARIABLE.TrackBary*8)>4){ VARIABLE.TrackBaryDecal--;}}else{VARIABLE.TrackBaryDecal=7;VARIABLE.TrackBary--;}}
To
if ((analogRead(A3)>=750)&&(analogRead(A3)<850)) {if (VARIABLE.TrackBaryDecal>0) {if (VARIABLE.TrackBaryDecal+(VARIABLE.TrackBary*8)>4){ VARIABLE.TrackBaryDecal--;}}else{VARIABLE.TrackBaryDecal=7;VARIABLE.TrackBary--;}} if ((analogRead(A3)>500)&&(analogRead(A3)<750)) {if (VARIABLE.TrackBaryDecal<7) {if (VARIABLE.TrackBaryDecal+(VARIABLE.TrackBary*8)<44){ VARIABLE.TrackBaryDecal++;}}else{VARIABLE.TrackBaryDecal=0;VARIABLE.TrackBary++;}}
* Don't forget when you program the cartridges, that Pin's 1 and 2 are swapped around on the Pacman and Tiny Arkanoid PCB's.
Great project. Very creative idea with the cartridges and it also looks beatiful.
Well done!!
