ino - 7.54 kB - 08/08/2018 at 14:21 |
Twitchbot Notification Thingy Manual (2).pdfOperation Instructions and setup After assembly and programming.Adobe Portable Document Format - 403.71 kB - 07/19/2018 at 12:11 |
esp8266 single led lid 2 slide fit.stl3D printed part to hold a wemos D1 Mini and an LED. Flip it in your slicing programStandard Tesselated Geometry - 133.48 kB - 07/19/2018 at 11:31 |
esp8266 single led Case 2 slide fit.stl3D printed part to hold a wemos D1 Mini and an LED.Standard Tesselated Geometry - 16.49 kB - 07/19/2018 at 11:31 |
esp8266 single led button.stl3D printed part to hold a wemos D1 Mini and an LED used to press the reset button.Standard Tesselated Geometry - 2.23 kB - 07/19/2018 at 11:31 |
