#un1eet Shitty Add On
an adventure into #badgelife SAO
I kept meaning to go through the tutorial on making custom PCBs and never got to it. But then I decided to make this for DefCon: an #un1eet SAO. Now I want to see where this goes.
I used this project to learn KiCad. Specifically I wanted to learn the workflow from Inkscape to KiCad for PCB art. I leveraged the Hardware Flair community, went through Getting to Blinky on Contextual Electronics,  watched #badgelife live streams by AND!XOR and TwinkleTwinkie. I kept pushing forward and now I have something shitty to share, trade and talk about with fellow folks.
  • 1
    Now Wat
    So you got your new #un1eet Shitty Add On  and you are wondering: Why did I buy a kit? I just want it to blind onlookers. Well, as part of the complete #un1eet experience, you must hack it together yourself with scant instructions.
    What you should do:
    Instructions Part 1
    1. read instructions in full
    2. chance the resistor around the board and nearly loose it
    3. after searching for 20 minutes on the floor, realize it was in a fold of your clothing the whole time
    4. tin one solder pad
    5. heat the pad and bring the resistor in to the melting solder, then pull the heat away while holding it in place until the solder hardens
    6. optional: realize you don't know what a resistor is and worry you just put the led on... no worries, it will work this way too just not as cool
    7. solder the other end of the resistor
    A quick note about the LED
    This is where things go off the rails and you have options. The LED can be mounted in two different ways. The way it was meant to be attached, which will point back at the wearer. OR The reverse mounting, which will point the light through the PCB and look really cool... ok, a little cool.
    Keep in mind, with the LED direction matters. So take a look at the bottom, there will either be two dots that indicate positive, or a line ending in a perpendicular line. The perpendicular line side is positive.
    Instructions part 2
    Repeat 'Instructions Part 1' only with the LED or whatever the other part is that is left over, you are doing fine, there is no wrong answer, only disappointment and failure. (don't fret no matter what, keep reading)
    Instructions part 3
    Solder the headers so they are out the back of the badge. You are DONE!
    When you get a Defcon Badge that supports the SAO standard, you will notice the dot, just line those up when you plug/solder them together.
    In spite of my joking around, this project is for you to learn on something that matters little. If this is your first time with SMD and you burn up parts, just order some random bags of 0805 SMD leds and resistors for a couple dollars on Amazon or AliExpress and go nuts.
    I would like to invent a term here. When you overheat, melt, wire in backwards or otherwise break electronics, especially when letting the sparks and blue smoke out, while assembling via soldering, we will no more call it failure or a mistake or an error or the ilk. This will furthermore be known among the #un1eet as Gleaming the Circuit.
  • 2
    Bonus Step: PARTY!
    Come to the Hacker Flairgrouns at Defcon and show off your #un1eet-ness !!
    What is Hacker Flairgrounds?
     It is a family friendly Bring-your-favorite-drink event to stand around and gock at different badges and toys and meet the makers and enthusiasts like yourself! (there will be cash drinks from the hotel too)
    When and where is it?
    8:30PM Saturday in the Flamingo Chillout
    (Laughlin)
    Already have a party that night? Good parties don't get going till about 9 or 10 anyway so come join us for a few while your party bakes for a bit. If your party is badge driven in any way, encourage everyone to walk through and show them off so we know what we missed out on! srsly, we want to see the badges and meet the ppl!
View all instructions
