Features
- 65C02 CPU by Rockwell operated at 3.6864 MHz (You can use the WDC version too)
- 32 kB of static RAM
- 8 kB of EEPROM
- ACIA 6551 for serial port, provides serial communication up to 19.200 Bd
- VIA 6522 for parallel port and counter/timer functions
- A "System Bus Connector" with data bus, address lines, control lines and decoded I/O addresses.
Martin Maly
Colin Maykish
See
https://maly.github.io/asm80-node/
