Soon to be available on Crowd Supply
06/01/2019 at 04:40 • 0 commentsIf you are interested in this project and would like to get one of these, I'm including one in my QwiiKit that will soon be available at Crowd Supply:
Communication through Qwiic Connector
10/01/2018 at 05:24 • 0 commentsHere is the board being accessed through the Qwiic connector:
There is also a video:
https://www.instagram.com/p/BoYK98fFmnP/?utm_source=ig_share_sheet&igshid=dxhbtd1k2cwn
See the instructions for more details on how to access the part through the Qwiic connector.
Obligatory Blinking LED Video
09/09/2018 at 15:06 • 0 commentsView this post on InstagramA post shared by Greg Steiert (@gregsteiert) on Sep 9, 2018 at 7:44am PDT
New Features
09/09/2018 at 04:18 • 0 commentsAt 15mm X 15mm, I undershot the 1 square inch by quite a bit. I am updating the layout to utilize some of that space. I'm adding some mounting tabs, but they will be v-scored so that you can break them off if all you want is the 15 x 15 mm NFC tag.
It's Alive
09/09/2018 at 04:07 • 0 commentsI had underestimated how difficult it would be to attach the uDFN package, but after a trip to the Ctrl-H Hackerspace in Portland, and some time with their soldering station I was able to get a few up and running. Here is one with the LED lit up.
Boards on the way
08/20/2018 at 03:55 • 0 commentsThe parts and boards have been ordered. Everything should be here this week.
I followed the reference design for one of the antennas pretty closely. Let's see how much effect the components and connector in the middle have on performance.
