ADC Board and/or Power Supply Issues Drum Scanner
Need help with a repair project - PLL errors in ADC board that uses Transputers. Power Supply giving lower voltage to motor.
I have what I think is an issue with the motor drive or PCB Mains for a drum scanner. Unfortunately it won't spin the drum and when I tested the voltage it says it's underpowered 117V instead of 220-240 to run it, but even when I use a transformer and it says 223V - it still says underpowered. There is also a PLL error I get when I run the PC diagnostics test. I would try swapping the ADC boards or power supply board but these are unobtainum. All manuals are below in the files section.
A link to the error on the Eurotherm Drive can be seen here showing it's undervoltage. https://photos.app.goo.gl/aUEZEanFkpzHbpR86A
A link to a teardown of a similar (but older model) machine can be seen here: https://www.youtube.com/watch?v=jM4_x7HReNM
ICG adc.pdf
Service Manual for ADC board
Adobe Portable Document Format - 8.08 MB - 08/26/2018 at 20:35
Preview
Download
icg mains .pdf
Machine controller PCB - Power Supply - Service Manual
Adobe Portable Document Format - 25.98 MB - 08/26/2018 at 20:35
Preview
Download
icg drive 2.pdf
Mechanical Drive System Service Manual
Adobe Portable Document Format - 7.68 MB - 08/26/2018 at 20:35
Preview
Download
icg debug test.pdf
Debug Test Service Manual
Adobe Portable Document Format - 7.40 MB - 08/26/2018 at 20:34
Preview
Download
icg drive.pdf
Motor assembly Service Manual
Adobe Portable Document Format - 11.84 MB - 08/26/2018 at 20:34
Preview
Download
View all 8 files
