May Update
05/31/2019 at 13:37 • 0 comments
After 3D printing the parts, the next steps we had to take were to configure the electronics on the drone. Betaflight was used to configure the flight characteristics of the drone. First the accelerometer was calibrated, then the ESCs. Next the transmitter was set up to communicate with the drone using the SBUS interface. The BLHeli configurator was used to ensure that the motors spin the correct direction before the propellers were attached. The camera subsystem was worked on separately to stream video that could be used for line detection.The line detection was done using C++, a coding language often used for image processing. The OpenCV library has a function called HoughLines that receives an image, grayscales it to reduce extraneous factors, and highlights the boundaries of the lines detected. The function considers each point on the image and defines a family of lines that go through that point. The lines, which are each defined by an r and θ value, are then plotted as a sinusoid. After each sinusoid is plotted, the function examines the intersections between them and the sinusoids that intersect are considered to be from the same line . A benefit of using this function is that it allows control of a threshold number of sinusoids in an intersection to be defined as a line, which can be used to reduce noise in an image and find only the necessary major line.
Many individual aspects of the drone were completed, however unfortunately we were unable to fully assemble our drone due to delays in shipping of parts, however we achieved successful results with line detection. In the beginning, though the lines were often detected, other objects and lines in the image were also highlighted. These other lines would affect our control of the drone’s movements, so we increased the threshold in order to only highlight the main line We hoped to use the detected lines as boundaries for the drone’s movements
April Update
04/08/2019 at 18:37 • 0 commentsI've researched parts and 3D printed a frame. Some of the parts have come in. I've started working on the software for the drone while waiting for parts. Depending on dimensions of the parts, I will have to modify the frame wot fit everything as well as to make it so that the camera is mounted under rather than on top of the drone.
January Update
01/23/2019 at 15:55 • 0 commentsI've decided to make a micro drone instead of a 5" drone because a micro drone will be easier and cheaper to make as well as fly. This requires me to find new parts and figure out what I need to transmit images/video and how to fit it onto a smaller frame. I've updated the timeline for this change.
December Update
12/07/2018 at 15:50 • 0 commentsSo far I've found which specific parts I want to use. I've decided on using BetaFlight and CL Racing F4S Flight Controller with a built in PDB and Aikon AK32 4-in-1 35A 6S BLHeli32 ESC. I've also found motors (Lumenier MX2206-9 2450KV Motor). For propellers, I'm going to use 5x4x3 propellors.
Timeline
11/02/2018 at 14:53 • 0 commentsI've decided to move away from doing a five inch drone in favor of making a micro drone. Here's an updated timeline
Finalize parts to order by 1/30
Figure out software related to getting the drone to fly 2/8
Assemble 2/15
Get it to fly w/ RC 3/1
Figure out how to transmit images 3/15
Integrate drone and image processing 3/25
