eyelashes-charlieplexed.pdfSchematic in PDFAdobe Portable Document Format - 120.19 kB - 09/04/2018 at 16:16 |
eyelashes-charlieplexed.inoArduino source codeino - 34.08 kB - 09/04/2018 at 17:38 |
eyelashes-charlieplexed.schkicad schematicsch - 18.81 kB - 09/04/2018 at 16:16 |
eyelashes-charlieplexed.kicad_pcbkicad pcb.Beware! I etched my own boards and milled the outline using a dremel. There is a 0ohm jumper that can easily be removed by adding some vias. But vias are a pain when building your boards at home. So double check before sending it to a Fab for manufacturing. kicad_pcb - 114.64 kB - 09/04/2018 at 17:44 |
eyelashes-charlieplexed.netkicad netlistnet - 18.50 kB - 09/04/2018 at 16:16 |
gerbers.zipGerben's gerbers q-;Beware! I etched my own boards and milled the outline using a dremel. There is a 0ohm jumper that can easily be removed by adding some vias. But vias are a pain when building your boards at home. So double check before sending it to a Fab for manufacturing. Zip Archive - 27.17 kB - 09/04/2018 at 17:49 |
circle-leds-A4.pdfI printed these arcs on transparency paper. I used superglue to temporarily attach the leds on the no-printed side. After soldering the wires, remove the leds from the sheet by soaking them in acetone.Adobe Portable Document Format - 51.95 kB - 09/05/2018 at 12:54 |
