Inspired from watching many of The Thought Emporiums' youtube videos: <a target="_blank" rel="noopener noreferrer" href="https://www.youtube.com/channel/UCV5vCi3jPJdURZwAOO_FNfQ">https://www.youtube.com/channel/UCV5vCi3jPJdURZwAOO_FNfQ</a>
1×
https://www.homedepot.com/p/Blaster-9-3-oz-Advanced-Dry-Lube-with-Teflon-16-TDL/202532762
Can of spray teflon lubricant for tripod moving components
On Discord I received some great help with troubleshooting my setup from Pietern ( developer of GOES Tools) and other members to determine my LNA was not working.
You could try mounting your dish at a 45 degree CCW rotation. This will match the vertical polarity of the signal and give you a better signal
At least, it will better match it, I think in california you need about 30 deg CCW, so if your mount allows it, then that's great, otherwise 45 is fine too
My permanent setup for GOES-16 in the SF bay area has this rotation as well
A 2.5cm spacer is required. I have 4mm nylon spacers on hand. After drilling the spacers out to slider over a 8-32 nylon screw, physically works to offset the secondary reflector. I have not yet tested
