XOR and XNOR simple as ever
A project log for LIGHT LOGIC - HIC SVNT DRACONES
Using a LED/LDR pair to form inverting Photonic logic gates. The entire Boolean logic set handled by resistors and diodes! Who'd'a thunk
Dr. CockroachDr. Cockroach 07/16/2019 at 10:012 Comments
I now have, thanks to @Starhawk for the nudge, managed to create A XOR and XNOR gate that uses just a single Light Logic switch. I no longer need to combine other gates for these logic functions. Logic highs are 4 volts or higher and the low levels are less than 0.5 Volts. Good enough to be used with the rest of the Light Logic family.
Dylan Brophy wrote 07/19/2019 at 20:13 point
That is the simplest XOR I think I've ever seen.  Congrats, good job!!
Yann Guidon / YGDES wrote 07/19/2019 at 19:57 point
HAH !!! Good job !
