pliers pin.SLDPRTThis is the pin that connects the joints in the assembly.sldprt - 125.50 kB - 10/15/2018 at 14:16 |
pliers part2.SLDPRTThis is the solid part for part one of the pliers.sldprt - 229.17 kB - 10/15/2018 at 14:15 |
pliers part1.SLDPRTthis is the solid part for part two of the pliers.sldprt - 285.20 kB - 10/15/2018 at 14:14 |
pliers part1.STLSTL for part one, or the handle. If you are printing, you will need two of these.Standard Tesselated Geometry - 118.05 kB - 10/15/2018 at 14:12 |
pliers part2.STLSTL for part two, or the tip. If you are printing, you will need two of these.Standard Tesselated Geometry - 31.72 kB - 10/15/2018 at 14:12 |
