Venta Connected
Adding WiFi control to a Venta LW45 humidifier using a custom PCB with a ESP8266
Public Chat
0 followers
In this project, I'm designing a WiFi-connected PCB that adds remote control capabilities to an old-school Venta LW 45 air humidifier.
The control panel - connected to the main PCB via a 10-pin ribbon cable - of the humidifier provides five LEDs indicating power status, level and error and two buttons to turn the device on/off and to change levels. I insert my own custom PCB where the ribbon cable is plugged in, thus allowing me to read out the HIGH/LOW status of each cable pin as well as pulling down each cable pin emulating a button press.
As the Venta LW45 is powered through an external 24V power supply, I tap into that power source, but need to convert to 3.3V for the ESP8266 that is used to provide the WiFi control.
To read out the status of the LEDs, I use LM339 / LM393 dual / quad differential comparators and to emulate button presses, I'm using three 2N7000 FET transistors.
More details about this project can be found in my extensive blog post: http://wiki.kainhofer.com/hardware/venta_connected
VentaConnected_ESP8266_V1.0_2018-10-06.sch
Schematics of the WiFi control board for the Venta LW45 humidifier
x-kicad-schematic - 1.81 MB - 10/14/2018 at 14:59
Download
Zip Archive - 133.67 kB - 10/14/2018 at 14:59
Download
VentaConnected_ESP8266_V1.0_2018-10-06.brd
PCB design of the project
x-kicad-pcbnew - 536.70 kB - 10/14/2018 at 14:59
Download
VentaConnected_ESP8266_V1.0_2018-10-06.pdf
Adobe Portable Document Format - 27.67 kB - 10/14/2018 at 14:59
Preview
Download
  • 1 × ESP-12e WiFi mofule
  • 1 × LM339 quad differential comparator SMD SO14
  • 2 × tactile switches SMD 6x3.5mm
  • 1 × 2x5pin boxed header male, 2.54mm pitch, through-hole
  • 1 × 2x5pin header female, 2.54mm pitch, through-hole
View all 13 components
View all instructions
