4 to 3 pin converter for CPU fan
How to connect 3 pin fan to 4 pin connector on motherboard
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
Recently I received a set of motherboard, CPU, memory and cooler to upgrade my PC. But the cooler has only 3 pin connector and does not slow down spinning rate. The motherboard has 4 pin connectors. So I decided to make some adapter. It works pretty well with my Huanan x79 board. I turned on smartfan feature in BIOS and slightly tuned it. So now the fan has about 500 rpm in idle state and 1500 rpm when CPU is fully loaded.
