Hackaday.io Hackaday.io
Sign up Log in
Linear Servo Actuators
This is a general purpose 3D printed linear servo actuator (pusher style). Hope these save you some time on a future project!
aliAli
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
17 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
726
0
17
17
Team (1)
  • aliAli
Join this project's team
  • Assembly video
completed project
Linear servo actuator diy 3D printed 3d printing
This project was created on 10/28/2018 and last updated 7 years ago.
Description
This is a general purpose linear servo actuator (pusher style). Two sizes have been designed, for different space constraints and force outputs.<br><br>These use continuous rotation servos which helps keep the cost very low. Off the shelf actuators of this type can cost around $70 USD.<br><br>The &#x201C;mini&#x201D; version will fit in smaller spacers, but has a much lower force output. The &#x201C;large&#x201D; version has a higher force output, but is...larger in size than the &#x201C;mini&#x201D;.<br><br>Here is a video that shows how to assemble and run both sizes:<br><a target="_blank" rel="noopener noreferrer" href="https://youtu.be/2vAoOYF3m8U">https://youtu.be/2vAoOYF3m8U</a><br><br>Links to STL files and a full parts list can be found in the video description.<br><br>**Please note that the best way to show your appreciation and keep up to date on my latest 3D printing projects is to head over to my YouTube channel and subscribe!**<br><a target="_blank" rel="noopener norefe
Project Logs
Collapse
  • Assembly Video and Link to STL files
    Ali • 10/28/2018 at 13:10 • 2 comments
View project log
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
Simple approach to a modular revolute actuator
Project Owner Contributor
Servo with integrated slew bearing
wmacalusowmacaluso
Hackaday Prize 2020
An almost completely 3D-printed servo which is able to pull a car forwards.
3D printed high torque servo/gearbox Version 2
brian-brockenBrian Brocken
The well known Raymarine (tm) ST1000 (and 2000?) series tiller auto pilot units have no limit switches built in risking self destruction.
Tiller Autopilot Limit Switches
dennisdennis
Off-the-shelf pickup sticks only work if the person has the grip strength needed. This is a servo-driven, three-jawed alternative.
Three-Jaw Grip-Stick
darkredhorsedarkredhorse
Going up?
© 2025 Hackaday
Yes, delete it Cancel
You are about to report the project "Linear Servo Actuators", please tell us the reason.
Send message
Remove Member
