dash_plugin.dllplugin to make ets 2 work with arduino (telementery data plugin) put it in you ets 2 root folder under bin/X64/pluginsx-msdownload - 47.50 kB - 11/13/2018 at 03:45 |
plugin.cppfile for the plugincpp - 12.36 kB - 11/13/2018 at 03:45 |
options.cppfile for the plugincpp - 2.94 kB - 11/13/2018 at 03:45 |
serial.cppfile for the plugincpp - 3.02 kB - 11/13/2018 at 03:45 |
serial.hppfile for the pluginhpp - 1.89 kB - 11/13/2018 at 03:45 |
options.hppfile for the pluginhpp - 2.21 kB - 11/13/2018 at 03:45 |
plugin.deffile for the plugindef - 111.00 bytes - 11/13/2018 at 03:45 |
dash_plugin.txtfile for the pluginplain - 375.00 bytes - 11/13/2018 at 03:45 |
arduino_controller.inoThis is the actual Arduino programing file i will be using to make the cluster work with ets 2ino - 6.84 kB - 11/13/2018 at 03:44 |
