1Get and install GHDL
get it there : https://github.com/ghdl/ghdl/releases
also read http://ghdl.free.fr/
Be sure to not use the MCODE version... The GCC and LLVM backends seem to work well.
2Test
under Linux :
wget https://cdn.hackaday.io/files/1625946956421696/A3Ptiles_v2.6_20191229.tgz tar xzvf A3Ptiles_v2.6_20191229.tgz cd A3Pv2.6 ./run_tests.sh
This will run scripts for a minute or so, compiling everything and testing the results for consistency.
3Use in your project
Copy (or symlink) the directory proasic3v2 in your project.
Use the tests/examples to setup your scripts and include the proper paths to the files.
Yann Guidon / YGDES
