Hackaday.io Hackaday.io
Sign up Log in
Telescoping Yagi Antenna with Folding Elements
Yagi antenna w/telescoping boom & elements based on the tape measure yagi by Joe Leggio (WB2HOL) and James T. Hanson (W1TRC) in May 2007 QST
james-finchJames Finch
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
Public Chat
1.1k views
1 comments
4 followers
  • Description
  • Details
  • Files 9
    • View all
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 1
View Gallery
Public Chat
1.1k
1
4
2
Team (1)
  • james-finchJames Finch
Join this project's team
  • Instructable
  • Youtube Update Dec. 2018
hardware
ongoing project
This project was created on 01/08/2019 and last updated 5 年前.
Description
A Telescoping Yagi Antenna with telescoping boom and telescoping antenna elements for mechanical tunability. The antenna elements also fold back for more compact portability. 01/17/2021 Update: Added new vers2 design files that fit SCH.40 1/2" PVC-1 D-2466 Tees. Also, no hole drilling required.
Details
Files
Yagi_Telescoping_Mount_v2_halfsz.gcode
gcode of the @ 0.1 vertical height (res), 30% honeycomb infill and 5 layers rectilinear perimeters for the MPSM V2
gcode - 6.82 MB - 01/18/2021 at 06:33
Download
Yagi_Telescoping_Mount_v2_halfsz.stl
Version 2.1 half length, 42mm design .stl
Standard Tesselated Geometry - 261.12 kB - 01/18/2021 at 06:32
Download
Yagi_Telescoping_Mount_v2.gcode
gcode of the @ 0.1 vertical height (res), 25% honeycomb infill and 5 layers rectilinear perimeters for the MPSM V2
gcode - 15.28 MB - 01/18/2021 at 04:43
Download
Yagi_Telescoping_Mount_v2.stl
Version 2 .stl
Standard Tesselated Geometry - 161.51 kB - 01/18/2021 at 04:39
Download
Yagi_Telescoping_Mount_v2.rsdoc
Version 2 in the DesignSpark Mechnical file format.
rsdoc - 144.38 kB - 01/18/2021 at 04:39
Download
View all 9 files
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
James Finch wrote 11/24/2021 at 00:07 • point
Just noticed I didn't reference using the Tecsun AN-07 Telescopic Antenna Extender on the reflecting elements.  Figured I'd note as an easy packable way to further mechanically tune the antenna a little lower down.
6 iterations of a design of something supposedly simple. Hold a vacuum cleaner attachment in place and not break during use.
Project Owner Contributor
Vacuum cleaner attachment holder
tom-baileyTom Bailey
My shower screen clip broke so I printed a replacement
Simple Shower Fix
andy-from-workshopshedAndy from Workshopshed
The 2015 Hackaday Prize
Provides simple digital MEMs microphone input through i2s. For sale on Tindie.
INMP441 MEMs Microphone
chris-hamiltonChris Hamilton
A new pen plotter design that doesn't occupy much space and works on polar coordinates.
Polar Sketcher
andr-esserAndré Esser
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Telescoping Yagi Antenna with Folding Elements", please tell us the reason.
Send message
Remove Member
