Hackaday.io Hackaday.io
Sign up Log in
Interfacing HC-05 Bluetooth module with ATmega8
Here we will establish a connection between the HC-05 ( connected to ATmega8 ) and an android Bluetooth app to blink a LED.
electronicsforgeekselectronicsforgeeks
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
Public Chat
2.4k views
1 comments
2.4k followers
  • Description
  • Details
  • Files 0
  • Components 7
    • View all
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 1
View Gallery
Public Chat
2.4k
1
2.4k
3
Team (1)
  • electronicsforgeekselectronicsforgeeks
Join this project's team
MISC
ongoing project
HC-05 Atmega8 bluetooth module UART
This project was created on 01/10/2019 and last updated 4 years ago.
Description
In this project, we are using the HC-05 bluetooth module and AVR ATmega8 microcontroller. Both HC-05 and ATmega8 is connected serially at a baud rate of 9600 (can be changed). we have connected an LED to one of the pin of ATmega8 and an android app is used to send data using UART protocol and when a certain data is sent from app then the action on LED shows up. For example when app sends 1 --> LED Glows and when app sends 0 --> LED turns off. The HC-05 and the bluetooth app must be connected to begin the communication and to connect to HC-05 the default password is 0000 or 1234.
Components
  • 1 × AVR ATmega8 It's a 8-bit controller from ATmel corporations.
  • 1 × HC-05 Bluetooth Module
  • 1 × USB-ASP Programmer To program ATmega8
  • 1 × LED Fiber Optics / Emitters
  • 1 × Jumper wires Male-Female/ Female-Female
View all 7 components
Project Logs
Collapse
  • update
    electronicsforgeeks • 01/10/2019 at 07:17 • 0 comments
    we have just started and as soon as we accomplish this project, will post here.
View project log
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
Lee Wilkins wrote 01/14/2019 at 20:47 • point
HC05 is great! I'm excited to see this tutorial.
Internet controlled 6x7 LED grid using an Adafruit Huzzah (ESP8266)
Project Owner Contributor
Adafruit Huzzah 42 Charlieplex LED grid
brandonhawkesbrandonhawkes
This time I will show you how to make balancing Led dot using WS2812 led strip and MPU6050 accelerometer and gyroscope module.
DIY Arduino Balancing Dot on Led strip
mircemkmircemk
Open-source, easy, cheap and modular solution to create connected LED Strip lighting Based on RPI server, esp32 and LED strips
Pixled Connected LED Strips
aubinrabouanaubinrabouan
Connected displayer
Smart Led Messenger
raphal-maginotRaphaël Maginot
Going up?
© 2025 Hackaday
Yes, delete it Cancel
You are about to report the project "Interfacing HC-05 Bluetooth module with ATmega8", please tell us the reason.
Send message
Remove Member
