Thermostat with InvIoT U1 (arduino compatible).
InvIoT U1 at kickstarter
There is a 24 hour temperature zone setting. Works for heating and A/C, with a force air or without a force air. A U1 and a 4 relay module is needed.
x-arduino - 15.78 kB - 10/16/2016 at 20:53
Setting up, connect relay, upload sketch
1. Download the library for the U1 model at InvIoT.com/download
2. Load the sketch in your arduino IDE. Go to menu file/examples/InvIoT/applications/thermostat
3. Set the pins depending on the relay module you have got.
4. Connect the wires to your heater/AC unit.
5. Upload the sketch
Setup menu:
Press the home button on U1 to set up the menu.
First setup the time and the unit that you are using (C / F).
If you like set time zones.
Used at your own risk. All the info, software and hardware is "AS-IS".
View all instructions
Alex Sokolsky
Jung Hoon Lee
Parker Newman
My Electronics
Yes, delete it Cancel
You are about to report the project "Arudino compatible thermostat", please tell us the reason.
