• Assembly of Rev.01
    Wim Van Gool09/06/2019 at 06:01 0 comments
    Some minor bugfixes in the LED Driver and and an updated way of lighting the name of each element. resulted in the creation of the new PCBs with revision 01.
    Paste is applied using a steel stencil, then everything is placed by hand and ready to go through the small converyor reflow oven!
  • Small test setup
    Wim Van Gool05/08/2019 at 17:05 0 comments
    We've managed to assembled the first 3 boxes with electronics in the small test setup. The concept works as intended. The communication test with the BeagleBoneBlack using the Bernardo cape was also successful. The sensitivity of the capacitive touch sensor is also increased so the presence of a hand is detected from a few centimeters in front of the glass. The glass itself is a triple layer museum glass panel of almost 3cm thick.
  • UV test
    Wim Van Gool05/08/2019 at 16:49 0 comments
    First test with the UV LEDs on some uranium glass.
  • Flex PCBs assembled
    Wim Van Gool05/08/2019 at 16:46 0 comments
    We assembled the first flex panel with the RGBW and UV LEDs.
  • Flex PCBs arrived
    Wim Van Gool03/18/2019 at 09:42 0 comments
    Since we will be using some high power LEDs to illuminate every element, we opted for a flex PCB which will be glued on a large custom copper heatsink. The boards arrived, the custom heatsinks should arrive soon. This heatsink will also place the LEDs in a nice angle towards the box and prevent us from blinding the people passing by.
  • First Prototypes assembled
    Wim Van Gool03/18/2019 at 09:37 0 comments
    We got our first boards and most of the components, assembled them at the FabLab Leuven Prototype Lab and got the Arduino bootloader loaded on all 3 prototypes boards. We're still missing a few components which have to be hand soldered (DIP Switch, M3 standoffs for proximity antenna)
