Designing Coils for PCB
03/08/2019 at 04:56 • 0 commentsI really just wanted to jump into this project, mainly with out thinking/looking
I've seen [Carl]'s projects hear and some of his progress on twitter. I popped open EagleCAD and went straight for the ULP's.
spiral-coil.ulp
copying the spec's from the original:
I went with 0.5 mm for the width and 30 turns as specified
I used 0.2 spacing as that is the minimum for flexible PCB from OSHpark
Which dumped out this:
I wasn't sure if i was going to be able to line up the vias since Eagle is a baby. I am going to look into separating this as well as spacing out the center to make a more usable coil for metal detecting.
---------- more ----------I streamed myself working on this
Watch Flex PCB Design Contest from tankstein on www.twitch.tv
Project Page Creation
03/08/2019 at 04:34 • 0 comments- Created page
- Added reference files
- Added new schematic design
Todo
- Get PCB made
- Test Components
- Create Detailed BOM
- Create Tindie Page
- Modify Design
- Iterate
Ray Olsen
