Wireless sensor for monitoring home plants.
This is a BLE sensor. It is quite easy to get measurement results and use in home automation with NODE RED or any MQTT based system.
Standard Tesselated Geometry - 41.49 kB - 04/15/2019 at 19:32
Standard Tesselated Geometry - 39.14 kB - 04/15/2019 at 19:32
A simple application for iOS / Android is ready. Supports multiple sensors.
View project log
Olivier Godfroid
Guy Cole
panovvv
grussell73
Yes, delete it Cancel
You are about to report the project "Plant Environment Monitor", please tell us the reason.
