2019-05-10-153016.webm
video of the laser cut MPRT
Open Web Media Project - Video - 4.57 MB - 05/10/2019 at 07:39
Download
MPRT-1.01.scad
Fully parametric, minimal version
x-openscad - 6.13 kB - 05/10/2019 at 07:09
Download
involute_gears.scad
Put in same directory as MPRT.scad
x-openscad - 18.16 kB - 05/10/2019 at 07:10
Download
MPRT-2.dxf
Elbow design
AutoCAD DXF - 1.69 MB - 05/04/2019 at 14:28
Download
MPRT-1.dxf
360 plus laser cut design
AutoCAD DXF - 2.32 MB - 05/04/2019 at 14:28
Download
elbow-LaserCut.dxf
A single stage planetary gear design I am proposing to get cut. Many to test the how good or bad the general concept is.
AutoCAD DXF - 320.62 kB - 05/03/2019 at 13:01
Download
TrimmedGear0.dxf
One of the 10 check files from TrimGear
AutoCAD DXF - 214.24 kB - 05/03/2019 at 12:58
Download
TrimGear.c
Trim Gear code. Not perfect but good enough (check the design for "burrs" before use..
x-csrc - 9.93 kB - 05/03/2019 at 12:58
Download
MPRT5-2.dxf
Working laser cut design file (not final)
AutoCAD DXF - 655.23 kB - 05/02/2019 at 11:12
Download
MPRT5.dxf
The basic gears (from Gear.c)
AutoCAD DXF - 395.58 kB - 05/02/2019 at 11:07
Download
dxfout.h
The self contained dxfout library I am using.
text/x-chdr - 4.36 kB - 04/20/2019 at 13:15
Download
ezx_graphics.pdf
The ezx graphical display user manual (Linux only)
application/pdf - 92.72 kB - 04/20/2019 at 13:15
Preview
win32_libezx.a
The ezx graphical display library (Windows).
Rename as libezx.a after download.
x-archive - 28.53 kB - 05/02/2019 at 11:07
Download
libezx.a
The ezx graphical display library (Linux)
application/x-archive - 28.44 kB - 04/20/2019 at 13:15
Download
ezxdisp.h
The ezx graphical display library header
text/x-chdr - 4.33 kB - 04/20/2019 at 13:15
Download
Gear.c
C code to generate MPRT5.dxf
Note: No user interface, hard coded!
Updated for laser cut width adjustment.
text/x-csrc - 12.75 kB - 04/17/2019 at 04:08
Download
MPRT.dxf
A Modified Planetary Robotic Transmission gear design concept.
AutoCAD DXF - 244.29 kB - 04/16/2019 at 13:11
Download
A pretty picture of the MPRT DXF
Portable Network Graphics (PNG) - 74.35 kB - 04/16/2019 at 13:11
Preview
