Programmers
Please have a look at our current software roadmap. Sixi 2 firmware is contained inside the Makelangelo firmware.
Circuit Benders
The current motherboard is an Arduino Mega with a custom PCB. The PCB was designed in KiCAD. KiCAD files - including the latest schematic and PCB layout - is in the Sixi 2 Github repository.
Engineers
We are still trying to build a process in the shop so that the STL files and BOM are always up to date with our current work. In the mean time, have a read-only look at our Sixi 2 Fusion360 project. You may be able to extract the BOM and STL files from there.
Assemblers
As opportunity arises we will be making videos showing assembly of each sub-component. If you are equipped with the parts and tools you should be able to follow the video playlist or the pictoral guide and build it yourself.
How to apply
Don't just send a generic "I think I'd be good" message. Make your case.
Dan Royer
Students in Montreal purchased our kit and used the open source instructions to build a Sixi robot for their autonomous rover competition. This is the latest in-progress shot I received. Nice nice nice!
OpenRomibo
Andreas Hoelldorfer
Try our Patreon! I'll even put your name in our next video. https://www.patreon.com/imakerobots
